Presentaciones
Moderadores: luichi, Foxtrot
tymongiffin
Presentaciones
Mensaje por tymongiffin »
Laminate Vs. Vinyl Flooring: Which Is The Right Choice
When an attractive, economical, and durable floor that can be installed by yourself is what you are looking for, there are two prominent options: laminate and vinyl.
They both look good, don't cost much, and can be handled by a DIYer. Many people even have a hard time telling them apart at first glance.
That said, many differences exist between laminate and vinyl flooring. In fact, some of them are so important that they can become a deal-breaker when customers make a choice.
  • Overview
Vinyl is a completely synthetic material. Tiles or sheets made of it usually have a base layer that is actually fiberglass coated in a plasticizer and PVC. The result is an embossed and printed sheet with a print layer on top.
More and more vinyl flooring products come with built-in underlayment. Manufacturers can decide to apply several wear layers and a no-wax polyurethane layer as well.
Vinyl planks have a thick core layer and multi PVC layers around it. These planks interlock each other side-to-side to create a floating floor.
In stark contrast, laminate products have a core layer made from wood by-products. Their top surface is also harder with a clear wear layer covering the printed designed layer beneath.
Like vinyl planks, built-in underlayment is optional. It is a great addition for those who don't want to bother with the task of rolling it out later.
  • Look
While vinyl and laminate flooring generally have a similar look, you may have better luck with laminate products if you want to mimic materials like ceramics, stone, and hardwood as closely as possible.
  • Heat And Water Resistance
Vinyl flooring is the winner here. Some of them are just water-resistant but also waterproof. Luxury vinyl, vinyl tile, and sheet vinyl flooring are your best bet when you need the highest level of waterproofing. They make great flooring in damp locations like basements and bathrooms.
On top of that, 12-foot wide sheets can eliminate the need for seaming, creating another layer of protection against water.
  • Cleaning
You can carry out almost every cleaning step on vinyl flooring, from wet cleaning with a Vinyl floor mop to sweeping. While laminate flooring isn't hard to clean, some of those cleaning tasks are impossible with it.
  • Stain Resistance
It is hard to pick the real winner here. Both modern laminate and vinyl flooring products can come with strong wear layers. They are treated and can resist stains pretty well.
  • Comfort
You can get a more comfortable, softer, and quieter floor with laminate. However, this can only be done when you combine it with felt or foam underlayment. When used alone, laminate floors feel hollower underfoot than wood floors.
  • Durability
Vinyl flooring products have solid durability, given its low-cost and low-maintenance nature. That is why they are a popular option in commercial settings, where maintenance and durability are crucial. Get the best mop for Vinyl floors, and they can last for a long time.
However, if you can keep your laminate floors dry and clean them regularly, their lifespan can get close to that of vinyl products.
Conclusion
There is no definite choice between laminate and vinyl flooring. While you should prioritize vinyl products for mudrooms, bathrooms, and laundry rooms (which will require you the right mops for Vinyl floors), laminate flooring can work well with dry areas.
Última edición por tymongiffin el 09 Ene 2023, 09:59, editado 1 vez en total.
As.Harley
Moto: VN 900 CLASSIC 2009
Socio: 1068-S
Re: Presentacionesp
Mensaje por As.Harley »
Hola desde Ronda
Re: Presentacionesp
Mensaje por Isaias »
Bienvenido al foro saludos desde Bizkaia
Re: Presentaciones
Re: Presentaciones
bienvenido........saludos desde Bizkaia!!!!!!!!!!
Fromero
Moto: Kawasaki vulcan 640
Re: Presentaciones
Mensaje por Fromero »
Hola a todos, recién adquirida mi kawa vulcan 650S
chiscova
Moto: kawa vn 900 classic
Re: Presentaciones
Mensaje por chiscova »
Bienvenido al foro, saludos desde Pucela
chiscova
Re: Presentaciones
Fromero escribió: 27 Ago 2022, 06:27 Hola a todos, recién adquirida mi kawa vulcan 650S
Me parece compi que te has colado en la presentación de otro compañero. Sin acritud eh?? Que esto de la informática es un mundo...
Re: Presentaciones
Bienvenido desde Málaga
